2011-02-04, 21:36
I know there are lot of renaming tools out there, but the ones I used I personally found too overblown with features which simply didn't do the job.
So, I decided to write my own. It focuses on renaming multiple tv show files so that they conform to XBMC conventions (S01E01), but also has some other features:
- Move files to your "library" in the applicable folder
- Clean up (remove) miscellaneous files leftover from downloads/extractions.
To install, unrar the file from the downloads section in the link below and follow the instructions in readme.txt.
Try it out, let me know what you think!
http://code.google.com/p/show-renamer/
Have fun,
http://www.towersofasia.com
Have fun,
