Full Version: Remote key shortcuts and the shutdown key
Hi all,
I have searched the forums for information on remote key shortcuts for iOS and can't find a single place that lists this. In particular, I am interested in the shutdown menu. I'm using Alaska Revisited and would like to hide the 'Setup' menu option from prying eyes, but don't want to do this until I have a way of bringing up the Shutdown menu.
From what I have read:
1. During video playback, press and hold the Play/pause button to bring up the OSD.
2. When in the GUI, press and hold the Menu button to bring up the context menu.
Any others? Perhaps these would be good to list in the FAQ.
play/pause does not work for me (although i am using the confluence skin)
Should be skin independent. Perhaps I got it wrong and it is the center button. It is definately working for me, but I can't confirm which button as I am at work. If you check I will edit my post accordingly.
There are more functions buried then this. I would grab a BT Keyboard and start experimenting with what each keypress does. Some of the standards do not work (m for context menu), but i have found some unusual ones...
Do believe that was the Center button.
