Hi everybody!
I haven't succed finding this: are the updates automatic or you have to ssh and type some command? And if that is the case, what command?
Thank you.
I found this on the xbmc.org home page and it worked well for me:
Update Instructions:
AppleTV2: Connect via SSH in and run “apt-get update && apt-get install org.xbmc.xbmc-atv2′”
iOS: Upgrade through Cydia.
They are not automatic. As far as i know, this is the same for all versions of XBMC.
dtviewer Wrote:I found this on the xbmc.org home page and it worked well for me:
Thank you very much! I was looking in the forums, not in the main page...sorry.
