2011-02-08, 07:42
I am currently using Sickbeard to create the .nfo and .tbn files for my TV shows. The problem is that I either have to create the data manually (from within Sickbeard) or wait until about 3AM for Sickbeard to automatically create it.
The issue I'm having is that sometimes my daughters will scan for new TV shows before the metadata has been created by Sickbeard. So instead of an Episode displaying as 1.1 Episode Name it shows as 1.1 1x01 (with no description).
The way I've been fixing this is to remove the shows from their directory and clean the library. I then move the shows back, create the metadata with Sickbeard and then rescan for new content. I'm sure I'm making this more difficult than they need to be. Is there any way to force XBMC to use the metadata it finds for an episode that's been previously scanned?
