Full Version: Autodetection of skin folder based on resolution is failed.
Have a nice day!
I want make a modification of Alaska skin for 4:3 screen resolutions, but dumb in this:
Quote:07:34:05 T:4216 M:929083392 NOTICE: Starting XBMC, Platform: Windows Vista, 32-bit Service Pack 2 build 6002. Built on Dec 17 2010 (SVN:35647, compiler 1500)
07:34:05 T:4216 M:929083392 NOTICE: Intel® Pentium® Dual CPU T2390 @ 1.86GHz
07:34:05 T:4216 M:929083392 NOTICE: Desktop Resolution: 1280x1024 32Bit at 60Hz
07:34:05 T:4216 M:929083392 NOTICE: Running with restricted rights
07:34:05 T:4216 M:929067008 NOTICE: Setup SDL
07:34:05 T:4216 M:928735232 NOTICE: Found screen: Универсальный монитор PnP on ATI Radeon Xpress 1200 Series , adapter 0.
07:34:05 T:4216 M:928727040 NOTICE: Primary mode: 1280x1024 @ 60.00 - Full Screen
07:34:06 T:4216 M:922112000 DEBUG: CWinSystemWin32::ResizeInternal - resizing due to size change (0,0,1280,1024 fullscreen)->(0,0,1280,1024 fullscreen)
07:34:06 T:4216 M:922095616 DEBUG: CWinEventsWin32::WndProcWindow is active
07:34:06 T:4216 M:916779008 DEBUG: CWinEventsWin32::WndProcWindow gained focus
07:34:06 T:4216 M:916746240 DEBUG: CRenderSystemDX::InitRenderSystem - trying D3D9Ex...
07:34:06 T:4216 M:914464768 DEBUG: CRenderSystemDX::InitRenderSystem - using D3D9Ex
07:34:06 T:4216 M:914411520 DEBUG: CRenderSystemDX::CreateDevice on adapter 0
07:34:06 T:4216 M:911552512 DEBUG: CRenderSystemDX::CreateDevice - adapter 0: atiumdag.dll, ATI Radeon Xpress 1200 Series , VendorId 4098, DeviceId 31042
07:34:06 T:4216 M:911552512 DEBUG: CRenderSystemDX::CreateDevice - using D3DCAPS2_DYNAMICTEXTURES
07:34:06 T:4216 M:911552512 DEBUG: CRenderSystemDX::CreateDevice - texture caps: 0x0007ED47
07:34:06 T:4216 M:911552512 DEBUG: CRenderSystemDX::CreateDevice - RENDER_CAPS_DXT
07:34:06 T:4216 M:911552512 DEBUG: CRenderSystemDX::CreateDevice - RENDER_CAPS_NPOT
07:34:06 T:4216 M:911499264 DEBUG: CWinSystemWin32::SetFullScreen (windowed fullscreen) on screen 0 with size 1280x1024, refresh 60.000000
07:34:06 T:4216 M:910151680 INFO: GUI format 1280x1024 1280x1024 @ 60.00 - Full Screen
07:34:06 T:4216 M:907304960 INFO: load skin from:C:\Users\Miller\AppData\Roaming\XBMC\addons\skin.alaska.mod
07:34:06 T:4216 M:907304960 INFO: Default 4:3 resolution directory is C:\Users\Miller\AppData\Roaming\XBMC\addons\skin.alaska.mod\PAL
07:34:06 T:4216 M:907304960 INFO: Default 16:9 resolution directory is C:\Users\Miller\AppData\Roaming\XBMC\addons\skin.alaska.mod\720p
07:34:06 T:4216 M:907304960 INFO: Loading skin includes from C:\Users\Miller\AppData\Roaming\XBMC\addons\skin.alaska.mod\720p\includes.xml
07:34:06 T:4216 M:903430144 INFO: load fonts for skin...
07:34:06 T:4216 M:903393280 INFO: Loading colors from C:\Users\Miller\AppData\Roaming\XBMC\addons\skin.alaska.mod\colors\CarbonMesh (Red).xml
07:34:06 T:4216 M:903385088 INFO: Loading fonts from C:\Users\Miller\AppData\Roaming\XBMC\addons\skin.alaska.mod\720p\Font.xml
07:34:06 T:4216 M:880291840 INFO: load new skin...
07:34:06 T:4216 M:880291840 INFO: Loading skin file: Home.xml
07:34:06 T:4216 M:879910912 INFO: Loading user windows, path C:\Users\Miller\AppData\Roaming\XBMC\addons\skin.alaska.mod\720p
Using Dharma 10.0 build
1280X1024 is not 4:3 aspect ratio? :confused2:
Is any chance to force XBMC to choose pal directory?
Any help will be appreciated! Thanks.
Hello... Anybody home? Huh
Someone, help me please!
(UP)
Just edit the skin's addon.xml -
PHP Code:
defaultresolution="720p"  defaultresolutionwide="720p"
No
I'm have two displays: one 1280X800(~16:9) notebook screen, and 1280X1024(4:3) desktop monitor. Point of skin modification is to make it work with both resolutions correctly...
No success so far...
btw: original addon.xml has defaultresolution="720p", it's I'm who changed it to "pal", for reaching needed effect.
