Full Version: Skins - Are they (easily) editable?
Hello
I have just downloaded and installed XBMC and so far, everything looks okay. However, a quick question on the skins - are they easily editable?
For instance, I ONLY need "Movies" and "TV Shows", so other headings such as "music" I would prefer to remove. Would this break XBMC?
This is also true for the weather, I don't want or need this feature so would prefer to remove it.
Sorry, this should have gone i the Skins section - **d'oh**
most of what you want to do is available under skin settings under the settings option. you can disable/enable menu options to your hearts content
**depends on the skin of course**
Okay, thanks Big Grin
I'll take a look.
