Full Version: Weird time bar in screen
I have a big black bar on screen which i don't get to disappear. It's the same bar you get as when you ask for the codec info, but then only with the queue time without the codec info.
Also see the image on the following link:
Link
How did it get there, and how can i make it disappear? Already tried a lot of key combinations.
As a last resort rename or delete the guisettings.xml in %appdata%\xbmc\userdata and this will reset everything to the defaults (without affecting your library or add-ons).
JR
Solved.
I noticed that in a windows screen something was "pushing" the #2 keystroke. So the computer constantly was processing the commando "2" without succes. This probably interfered with XBMC. The error might have been caused by the instance of mediaportal running at the same time for a short period at a certain time. Killing MP didn't solve the conflicts between the two programs.
A reboot solved everything.
