2011-09-18, 00:08
Pages: 1 2
2011-09-18, 00:09
Varming Wrote:The link I posted is actually to a newer posting than what was posted earlier in this thread - that's why I posted it ;-)
exactly, it was updated to use the info i posted in this thread
2011-09-18, 00:10
Ah sorry, I didn't catch that part of it - sorry :-)
2011-09-19, 08:27
I have now credited you dear t0mm0 in the latest version of the post. I am sorry to not have done this initially. All thanks goes to you!
With your info and a bit of time on my side there might soon be another mixcloud tool, I am looking at AutoIt currently in my spare time and perhaps something can be done with that.
2011-12-01, 12:57
I don't know about xbbx's work but ... yesterday I did it.
I made a very basic addin that can browse all popular and new mixcloud cloudcasts (no search funtionality yet).
Also, it auto detects which stream works.
2011-12-04, 09:24
Would you like to share?
2011-12-07, 10:24
Varming Wrote:Would you like to share?
Shure, I will post a beta in day or two, need to clean up code first
The plugin has more or less "complete" functionality now.
2011-12-07, 10:52
jackyNIX Wrote:Shure, I will post a beta in day or two, need to clean up code first
Looking forward to this one
Thanks JackyNIX... Really appreciate your work on this.
2011-12-07, 16:24
et voila... http://forum.xbmc.org/showthread.php?tid=116386
2011-12-07, 18:18
t0mm0 Wrote:wow, that's a complicated way of doing it
i was thinking more of just using their api (for example, for the 'cloudcast' that blog post uses as an example check out http://www.mixcloud.com/api/1/cloudcast/...=cloudcast)
the rest of their api (for searching and stuff like that) is documented here.
the only annoying thing is that some of the links return a 404 (their own player just keeps trying until it finds a real link!) so you need to test that before passing the link to the xbmc player.
i will get to it eventually if nobody else cuts in, but i'm currently sidetracked with the urlresolver project.
t0mm0
Hi t0mm0, I only hope that you still have some time to unable the Veetle pluging to show HD videos
Really looking forward to it......
Pages: 1 2
