Full Version: Slide out menus showing...
Hey folks, I've installed the "Night "skin and used the default skin "Confluence", and in either case I can "see" the slide out menus under the main menu. I have a screen shot attached. Anybody have a clue why this is happening, or how to fix? Thanks.
http://img199.imageshack.us/i/menuxt.jpg/
You are using an old build. Upgrade.
Will do update and will let cha know if it works..........Thanks for the quick response.
Piotr, u are de man!!!!!!! That did the trick. This lil black puck, and all the developers hard work is a freaking thing of beauty! Now.... got to show it off to a couple of friends! Thanks again.
