Full Version: Problem with RSS feed
hi,
i have a problem with the RSS Feed.
I have a transparent bar for the rss feed which you always see,if RSS is en or disabled.
And i have a NOWPLAYING Window near the middle of screen.
Now when i enable RSS the Feed shows in the transparent bar on the bottom of the screen but the NOWPLAYING is moving up for the high of the RSS Feed.
How can i avoid this?
I searched all RSS setting etc but couldnt find the cause why its doing like this.
Really need help on this ...
most likely a conditional animation based on
system.getbool(lookandfeel.enablerssfeeds)
yes your right,thats it.
Thank you.
I have one really strange problem (at least, strange for me) Smile
I had RSS and everything worked fine, but suddenly I've changed RSS adresses and settings and since then, I can't get RSS to work, When I try to change RSS feeds I get this message
I've tried to unninstall RSS addon and to install it again, but still the same problem. I've tried to delete data (like it suggests in windows message) but still no changes. And I guess I've tried everything that comes to my mind Smile
Is there any help?
Edolee Wrote:Is there any help?
try here:
http://forum.xbmc.org/showthread.php?tid=81720&page=10
