Full Version: Irregular no sound issues on HD videos
I've some trouble with no sound issues on HD videos. The sound is ok for most of the time, but suddenly I've got no sound when playing a new video. Reboot usually fixes the problem.
xbmc.log - video with sound: http://pastebin.com/hz26cfGs
xbmc.log - video without sound: http://pastebin.com/qjeidpJU
I suspect the line wth "NOTICE: Opening audio stream: 0 source: 256" has something to do with my problem. It's 1 on the video with sound.
I've got a Nvidia 9400 connected to a H&K AVR255 receiver throught HDMI. Running Dharma on a Ubuntu Maverick minimal install with Nvidia 270 driver.
Can somebody please help me? Sorry for my bad english.
Cheers
I get the same problem
Never used to happen, but for some reason 50% of the time an HD video will start with no Sound. usually stopping the film and starting it again fixes the problem (sometime restart a couple of times)
This has only started happening since iv Added a new hard drive and moved my media around. I deleted my database/thumbnails and rescanned my library and it all appears fine and all SD videos work with out issue. I'm planning on formatting my PC and starting a fresh soon so hopefully a fresh install of XBMC should fix the issue.
Up
Can you turn on debug logging and repost the logs.
Thank you for your respons. Here is the debugging log:
http://pastebin.com/wquChk2s
No sound from line 3136 and down.
The log shows no problems with audio playback.
