2015-04-29, 18:01
2015-07-25, 01:02
Addon doesnt work anymore (at least it seems so.)
Do always get script errors and cant play anithing nor something get listed.
heres a part of the Log (the whole log is in the Link below)
And here the Whole Log (pastbin)
Regards
00:51:22 T:8000 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'urllib2.HTTPError'>
Error Contents: HTTP Error 404: Not Found
File "C:\Users\User1\AppData\Roaming\Kodi\addons\plugin.video.sf-videoportal\videoportal.py", line 224, in <module>
ok = show_sendungen_dynamic(MODE_SENDUNGEN_MOSTVIEWED)
File "C:\Users\User1\AppData\Roaming\Kodi\addons\plugin.video.sf-videoportal\videoportal.py", line 176, in show_sendungen_dynamic
soup = BeautifulSoup( fetchHttp( url, {"count": 25, "mode": "tabcontainer"}))
File "C:\Users\User1\AppData\Roaming\Kodi\addons\script.module.mindmadetools\lib\mindmade.py", line 59, in fetchHttp
response = urllib2.urlopen( req)
File "C:\Program Files\Kodi\system\python\Lib\urllib2.py", line 127, in urlopen
return _opener.open(url, data, timeout)
File "C:\Program Files\Kodi\system\python\Lib\urllib2.py", line 410, in open
response = meth(req, response)
File "C:\Program Files\Kodi\system\python\Lib\urllib2.py", line 523, in http_response
'http', request, response, code, msg, hdrs)
File "C:\Program Files\Kodi\system\python\Lib\urllib2.py", line 442, in error
result = self._call_chain(*args)
File "C:\Program Files\Kodi\system\python\Lib\urllib2.py", line 382, in _call_chain
result = func(*args)
File "C:\Program Files\Kodi\system\python\Lib\urllib2.py", line 629, in http_error_302
return self.parent.open(new, timeout=req.timeout)
File "C:\Program Files\Kodi\system\python\Lib\urllib2.py", line 448, in error
return self._call_chain(*args)
File "C:\Program Files\Kodi\system\python\Lib\urllib2.py", line 531, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 404: Not Found
00:51:22 T:7440 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.sf-videoportal/?mode=mostviewed&title=Meistgesehen
00:51:22 T:7440 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.sf-videoportal/?mode=mostviewed&title=Meistgesehen) failed
Regards
2015-07-25, 15:50
Yup, they changed some things again at srf, the json links the addon used to scrape return a 500 error now.
2015-11-02, 11:37
Any plans of resurrecting this? There is the SRF Podcast plugin but it is missing quite a lot of the content this used to provide
2016-02-15, 17:49
Hey all,
The former SF Videoportal is back. It's now called "Play SRF" and is a complete rewrite.
It does no more parse HTML, but accesses the available JSON API.
This thread may end here. Let us continue on:
http://forum.kodi.tv/showthread.php?tid=259948
Enjoy,
skandi
Enjoy,
skandi
