All is working on mac mini1.83ghz my only issue how do I clear my cache files without losing all my data. The arson for asking is when I use the remote xbmc commander displays tv shows with weird results
Paulkai,
What I do is export my video libray to a single file first. Exit XBMC. Make a backup of ~/Library/Application Support/XBMC. I then remove userdata/thumbnails and userdata/Database. Re-start XBMC. I then re-import the video library, both userdata/Database and userdata/Thumbnails will be rebuilt. This might help you.
