Full Version: EPG Missing in Git Feb 11
PVR Input is now fixed.. (Thanks)..
But I have no EPG, nor recordings..
Offending lines in log appear to be:
09:13:04 T:2976897904 M:1469394944  NOTICE: Epg - Load - no entries found in the database for table 16. trying to load 3 hours from clients.
09:13:04 T:2976897904 M:1469394944  NOTICE: Epg - Load - no entries found in the database for table 17. trying to load 3 hours from clients.
09:13:04 T:2976897904 M:1469394944  NOTICE: Epg - Load - no entries found in the database for table 18. trying to load 3 hours from clients.
09:13:04 T:2976897904 M:1469394944  NOTICE: Epg - Load - no entries found in the database for table 19. trying to load 3 hours from clients.
09:13:04 T:2976897904 M:1469394944  NOTICE: Epg - Load - no entries found in the database for table 20. trying to load 3 hours from clients.
09:13:04 T:2976897904 M:1469394944  NOTICE: Epg - Load - no entries found in the database for table 21. trying to load 3 hours from clients.
09:13:04 T:2976897904 M:1469394944  NOTICE: Epg - Load - no entries found in the database for table 22. trying to load 3 hours from clients.
09:13:04 T:2976897904 M:1469394944  NOTICE: Epg - Load - no entries found in the database for table 23. trying to load 3 hours from clients.
09:13:04 T:2976897904 M:1469394944  NOTICE: Epg - Load - no entries found in the database for table 24. trying to load 3 hours from clients.
09:13:04 T:2976897904 M:1469394944  NOTICE: Epg - Load - no entries found in the database for table 25. trying to load 3 hours from clients.
09:13:04 T:2976897904 M:1469140992    INFO: EpgContainer - UpdateEPG - finished loading 956 EPG tables after 1.173 seconds
09:13:04 T:2976897904 M:1469140992  NOTICE: Start - EPG thread started
09:13:04 T:2976897904 M:1469140992   DEBUG: PVRTimers - Update - updating timers
09:13:04 T:2976897904 M:1469140992   ERROR: AddOnLog: xbmc.pvrclient/VDR VNSI Client: cVNSIData::GetTimersCount - Can't get response packed
09:13:04 T:2976897904 M:1469140992   ERROR: AddOnLog: xbmc.pvrclient/VDR VNSI Client: cVNSIData::GetRecordingsCount - Can't get response packed
09:13:04 T:2985290608 M:1469140992   DEBUG: thread start, auto delete: 0
09:13:04 T:2985290608 M:1469140992  NOTICE: EpgContainer - UpdateEPG - starting EPG update for 956 tables (update time = 7200)
09:13:04 T:2985290608 M:1469140992    INFO: UpdateFromScraper - updating EPG for channel '13-WREXDT_(WREX-DT) NBC_Affiliate qam' from client '1'
09:13:04 T:2985290608 M:1469140992   ERROR: AddOnLog: xbmc.pvrclient/VDR VNSI Client: cVNSIData::GetEPGForChannel - Can't get response packed
09:13:04 T:2985290608 M:1469140992   ERROR: PVR: VDR VNSI Client/127.0.0.1:34890 - Client returns bad error (-3) after GetEPGForChannel
09:13:04 T:2985290608 M:1469140992   ERROR: EpgContainer - UpdateEPG - failed to update table 0
09:13:04 T:2985290608 M:1469140992    INFO: UpdateFromScraper - updating EPG for channel '14-WREXDT2_(WREX-DT2) CW_Affiliate qam' from client '1'
09:13:04 T:2985290608 M:1469140992   ERROR: EpgContainer - UpdateEPG - failed to update table 1
09:13:04 T:2985290608 M:1469140992    INFO: UpdateFromScraper - updating EPG for channel '16-WTVODT2_(WTVO-DT2) MyNetworkTV_Affiliate qam' from client '1'
09:13:04 T:2985290608 M:1469140992   ERROR: EpgContainer - UpdateEPG - failed to update table 2
09:13:04 T:2985290608 M:1469140992    INFO: UpdateFromScraper - updating EPG for channel '17-WTVODT_(WTVO-DT) ABC_Affiliate qam' from client '1'
09:13:04 T:2985290608 M:1469140992   ERROR: EpgContainer - UpdateEPG - failed to update table 3
... Snipped09:13:07 T:2985290608 M:1469288448    INFO: UpdateFromScraper - updating EPG for channel 'FM 105.7MHz-WNIJ' from client '1'
09:13:07 T:2985290608 M:1469288448   ERROR: AddOnLog: xbmc.pvrclient/VDR VNSI Client: cVNSIData::GetEPGForChannel - Can't get response packed
09:13:07 T:2985290608 M:1469288448   ERROR: PVR: VDR VNSI Client/127.0.0.1:34890 - Client returns bad error (-3) after GetEPGForChannel
09:13:07 T:2985290608 M:1469288448   ERROR: EpgContainer - UpdateEPG - failed to update table 955
09:13:07 T:2985290608 M:1469288448    INFO: EpgContainer - UpdateEPG - finished updating 956 EPG tables after 1.384 seconds
09:13:08 T:2985290608 M:1469648896  NOTICE: EpgContainer - UpdateEPG - starting EPG update for 956 tables (update time = 7200)
09:13:08 T:2985290608 M:1469648896   DEBUG: EpgDB - PersistLastEpgScanTime - updating last scan time of table 0 to '2011-02-11 09:13:08'
09:13:08 T:2985290608 M:1469648896    INFO: EpgContainer - UpdateEPG - finished updating 956 EPG tables after 0.25 seconds
09:13:11 T:3022468992 M:1469829120   DEBUG: UPower: Recieved an unknown signal DeviceChanged
09:13:14 T:2871339888 M:1469321216   DEBUG: Thread 2871339888 terminating (autodelete)
09:13:14 T:2882501488 M:1469321216   DEBUG: Thread 2882501488 terminating (autodelete)
09:13:14 T:3022468992 M:1469329408   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib-i486-linux.so)
09:13:14 T:3022468992 M:1469329408   DEBUG: Unloading: ImageLib-i486-linux.so
09:13:14 T:3022468992 M:1469329408    INFO: CheckIdle - Closing session to http://newsrss.bbc.co.uk (easy=0x9237150, multi=0x9256ec8)
09:13:14 T:3022468992 M:1469329408    INFO: CheckIdle - Closing session to http://xoap.weather.com (easy=0xafd223d8, multi=0xafd0aa30)
09:13:41 T:3022468992 M:1469837312   DEBUG: UPower: Recieved an unknown signal DeviceChanged
09:13:45 T:3022468992 M:1469845504   DEBUG: SECTION:UnloadDll(libcurl.so.4)
09:13:45 T:3022468992 M:1469845504   DEBUG: Unloading: libcurl.so.4
09:14:09 T:2985290608 M:1469906944  NOTICE: EpgContainer - UpdateEPG - starting EPG update for 956 tables (update time = 7200)
09:14:09 T:2985290608 M:1469906944   DEBUG: EpgDB - PersistLastEpgScanTime - updating last scan time of table 0 to '2011-02-11 09:14:09'
09:14:09 T:2985290608 M:1469906944    INFO: EpgContainer - UpdateEPG - finished updating 956 EPG tables after 0.34 seconds
09:14:11 T:3022468992 M:1469784064   DEBUG: UPower: Recieved an unknown signal DeviceChanged
I'd updated my vdr-plugin too... Antiquated seems fine with new plugin..
known issue
edit:
hmm no, that's not the "general epg issue", that's something with the vdr plugin. you should notify the guys who are maintaining it on github
Ok, PM'd pipelka. Thanks...
Btw, xbmc/pvrinput displays a channel a few seconds faster in the latest git than antiquated..
OK, Epg is now working, however recordings aren't.
Epgsearch has been recording series in sub directories under their episode name. I used to click on Program name, then Episode name, however, now I have one big list with no Program names. So, for instance, I have eight recordings called Pilot, but am not sure which program this is referreing to.
None of these play mind...
Is it possible to have the two ways (old and new) switchable in a config somewhere?
no
In that case, can we put the Program name back in the title?
It's in the info file in the recording:
C A-0-33230-3 17-WTVODT_(WTVO-DT) ABC_Affiliate qam
E 54 1297303200 1860 CB 18
T Modern Family
S Bixby's Back
This is just listed as Bixby's Back in the list of recordings instead of Modern Family.
Directory Tree is:
/var/video/Modern_Family/Bixby's_Back/2011-02-09.19.58.17-0.rec
rdoac Wrote:Ok, PM'd pipelka. Thanks...
Do you actually know pipelka's nick on this forum?
Cheers...
if you can't find him here, you could send him a message through github.
It should show as directory Modern_Family with content Bixby's_Back in XBMC , isn't that the case ? Need to check later on.
