Full Version: [linux] slow movie start / no subtitles
hi,
i've been using xbmc sucessfuly for the last 2 years now on linux with couple minor problems that I could resolve by search and/or google however
recently however when I moved to new a version I encountered a problem and that I cant handle myself.
My setup is as follows:
-FreeNAS storage serves files via SMB (NTFS partitions)
-zotac ion with atom with Arch Linux (minimal install) as a reciever
All movie files play smoothly (even 1080p), except those with TXT subtitles.
It takes forever to start the movie with subtitles and they don't show up at all.
What I figured out is, when I start the movie there is a "subtitle.txt" file in the ".xbmc/temp" folder that keeps on growing up to 2G
(attached picture from winscp here: http://img135.imageshack.us/img135/7840/xbmctemp.jpg)
Just a simple txt file with all the subs and extra empty data being written to it. After a minute or so file dissapears (deleted) and move starts playin (without subtitles !). Same thing happens when I try to choose subtitles during the movie - but the filename is subtitle.browsed.txt
Same here- file keeps on growing to 1-2GB and vanishes.
That causes the slow movie start - it waits to file grow so large.
Attached is a debug log.
http://pastebin.com/gAEJMmHV
but here's a part of it
PHP Code:
13:26:49 T:2796006256 M:1700077568  NOTICECreating InputStream
13
:26:49 T:2796006256 M:1700077568   DEBUGCFileSMB::Open opened movies/Vexille/VEXILLE.avifd=10000
13
:26:49 T:2796006256 M:1700077568    INFOCDVDFactorySubtitle::GetSubtitlessearching subtitles
13
:26:49 T:2796006256 M:1700077568   DEBUGCacheSubtitlesSTART
13
:26:49 T:2796006256 M:1700077568   DEBUGCacheSubtitlesChecking for common subdirs...
13:26:49 T:2796006256 M:1700077568   DEBUGCacheSubtitlesDone (time20 ms)
13:26:49 T:2796006256 M:1700077568   DEBUGCacheSubtitlesSearching for subtitles...
13:26:49 T:2796006256 M:1700077568   DEBUGOpenDir Using authentication url smb://192%2e168%2e0%2e191/movies/Vexille
13:26:49 T:2796006256 M:1700077568   DEBUGCFileSMB::Open opened movies/Vexille/VEXILLE.txtfd=10001
13
:26:49 T:3022309248 M:1700225024   DEBUG: ------ Window Init (DialogBusy.xml) ------
13:27:15 T:2756651888 M:1692151808   DEBUGThread 2756651888 terminating (autodelete)
13:27:15 T:2730875760 M:1015046144   DEBUGThread 2730875760 terminating (autodelete)
13:27:16 T:2836339568 M:1692168192   DEBUGThread 2836339568 terminating (autodelete)
13:27:16 T:2820954992 M:1692028928   DEBUGThread 2820954992 terminating (autodelete)
13:28:05 T:2796006256 M:1677533184   ERRORCache Failed write to file special://temp/subtitle.txt
13:28:05 T:2796006256 M:1677533184   DEBUGCFileSMB::Close closing fd 10001
13
:28:06 T:2796006256 M:1699930112   DEBUGCacheSubtitlesDone (time76491 ms)
13:28:06 T:2796006256 M:1699930112   DEBUGCacheSubtitlesEND (total time76515 ms)
13:28:06 T:2796006256 M:1699930112    INFOCDVDFactorySubtitle::GetSubtitlessearching subtitles done
13
:28:06 T:2796006256 M:1699930112  NOTICECreating Demuxer
btw: Windows installation works ok Sad
Please can you throw some ideas to help me out?
anybody? pls...
bns
ok this MAY be relatedo to either NTFS or SMB
I put my subtitles to local folder (home folder) and it plays flawlessly (no wait time at all)
but when there are subs both remotely in NAS and local folder xbmc seems to be searching for the subtitles remotely first (the location where the original movie file is) and then localy - partialy the same story - a minute wait time before movie starts but there are subs on the movie - I guess xbmc read local ones
temporary solution - MOVE all subtitles to local xbmc instalaton (so xbmc does not read remote ones)
to remind - ntfs via smb through freenas (freebsd) being read by arch linux (ext4 filesystem)
this may cause the confusionLaugh
tomorow I will try to move some of my shares to some linux / solaris not decided yet partitions with either EXT filesystem or ZFS, and see what happens
will let you know
if anybody has any expirience with similar proble please let me know - win box is not an option here Wink
bns
moved to ext4 via nfs - problem vanished - I dunno what was the reason, but its gone. Cost me a couple of days of data moving.
