2011-02-12, 23:04
I've installed XBMC 10 from the Live CD and trying to setup a share to get/put media on the XBMC box itself.
This would be easier for me rather than setup multiple shares to mount on XBMC and have to then ssh/go to the XBMC box to copy.
One suggestion I found was to install samba but this isn't working atm.
Or do I have to forgo the Live CD install and start with an OS install from scratch?
sudo apt-get install samba
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
samba: Depends: update-inetd but it is not going to be installed
E: Broken packages
