Full Version: shortcut to subtitles
i have a question about making/creating a shortcut for remote in xbmc.
When i want to watch a movie/serie i usually want to watch it with (dutch) subtitles. The situation right now is:
1) i start the movie
2) i go to play menu
3) i go to subtitle addon(movie paused)
4) i choose the subtitle
5) i watch the movie
Is there a way to make a shortcut (for remote) wich goes directly to the subtitle addon?
Thanx!
Btw. i am using xbmc for windows on an asrock ion 330 with a logitech harmony 525 remote
This for the keyboard .. copied it from anothe post:
you could bind it to a key (in this example 'u'):
Create a keymap.xml in your xbmc profile 'XBMC\userdata\keymaps' with content:
<keymap>
<FullscreenVideo>
<keyboard>
<u>RunScript(script.xbmc.subtitles)</u>
</keyboard>
</FullscreenVideo>
</keymap>
Does this help?
(T to toggle subs on and off.)
EDIT: Apologies, just seen you only need it for a remote.
costa Wrote:This for the keyboard .. copied it from anothe post:
<keymap>
<FullscreenVideo>
<keyboard>
</keyboard>
</FullscreenVideo>
</keymap>
perfect!!!! thanx a lot
Thanks costa, exactly what I need.
S@
FYI, in Gotham and up, this has changed to:
<keymap>
<FullscreenVideo>
<keyboard>
    <u>ActivateWindow(SubtitleSearch)</u>
</keyboard>
</FullscreenVideo>
</keymap>
( add the single row to keymap.xml in section FullscreenVideo->keyboard to set keyboard shortcut for subtitle search to u )
thanx evershift. it works.
