Using Windows, XP Home. XBMC is version 10.0 (latest i think?)
Here is the debug log of a quick few seconds of running avatar, stuttering occurs quite immediate. It matters not if its allowed to 'settle', it gets worse the longer u leave it (eventual audio sync issues). Of course on resume it takes awhile to settle but thats to be expected but if playing file from the start stuttering kicks in first 5-10secs in.
FYI i just did this on my desktop monitor, but i have another 27inch full HD 1080p monitor but its the same stuttering results.
13:23:37 T:3152 M:1030234112 NOTICE: -----------------------------------------------------------------------
13:23:37 T:3152 M:1030209536 NOTICE: Starting XBMC, Platform: Windows XP Home Edition Service Pack 3 build 2600. Built on Dec 17 2010 (SVN:35647, compiler 1500)
13:23:37 T:3152 M:1030209536 NOTICE: AMD Athlon 64 X2 Dual Core Processor 4800+
13:23:37 T:3152 M:1030209536 NOTICE: Desktop Resolution: 1680x1050 32Bit at 60Hz
13:23:37 T:3152 M:1030209536 NOTICE: Running with administrator rights
13:23:37 T:3152 M:1030209536 NOTICE: special://xbmc/ is mapped to: C:\Program Files\XBMC
13:23:37 T:3152 M:1030205440 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files\XBMC
13:23:37 T:3152 M:1030205440 NOTICE: special://masterprofile/ is mapped to: C:\Documents and Settings\Bruce\Application Data\XBMC\userdata
13:23:37 T:3152 M:1030205440 NOTICE: special://home/ is mapped to: C:\Documents and Settings\Bruce\Application Data\XBMC
13:23:37 T:3152 M:1030205440 NOTICE: special://temp/ is mapped to: C:\Documents and Settings\Bruce\Application Data\XBMC\cache
13:23:37 T:3152 M:1030205440 NOTICE: The executable running is: C:\Program Files\XBMC\XBMC.exe
13:23:37 T:3152 M:1030205440 NOTICE: Log File is located: C:\Documents and Settings\Bruce\Application Data\XBMC\xbmc.log
13:23:37 T:3152 M:1030205440 NOTICE: -----------------------------------------------------------------------
13:23:37 T:3152 M:1030184960 NOTICE: Setup SDL
13:23:37 T:3152 M:1029902336 NOTICE: Found screen: Plug and Play Monitor on NVIDIA GeForce 8800 GTS, adapter 0.
13:23:37 T:3152 M:1029894144 NOTICE: Primary mode: 1680x1050 @ 60.00 - Full Screen
13:23:37 T:3152 M:1029894144 NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
13:23:37 T:3152 M:1029890048 NOTICE: Additional mode: 640x480 @ 72.00 - Full Screen
13:23:37 T:3152 M:1029890048 NOTICE: Additional mode: 640x480 @ 75.00 - Full Screen
13:23:37 T:3152 M:1029890048 NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
13:23:37 T:3152 M:1029890048 NOTICE: Additional mode: 800x600 @ 72.00 - Full Screen
13:23:37 T:3152 M:1029890048 NOTICE: Additional mode: 800x600 @ 75.00 - Full Screen
13:23:37 T:3152 M:1029890048 NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
13:23:37 T:3152 M:1029890048 NOTICE: Additional mode: 1024x768 @ 70.00 - Full Screen
13:23:37 T:3152 M:1029890048 NOTICE: Additional mode: 1024x768 @ 75.00 - Full Screen
13:23:37 T:3152 M:1029890048 NOTICE: Additional mode: 1152x864 @ 75.00 - Full Screen
13:23:37 T:3152 M:1029890048 NOTICE: Additional mode: 1280x960 @ 60.00 - Full Screen
13:23:37 T:3152 M:1029890048 NOTICE: Additional mode: 1280x1024 @ 60.00 - Full Screen
13:23:37 T:3152 M:1029890048 NOTICE: Additional mode: 1280x1024 @ 75.00 - Full Screen
13:23:37 T:3152 M:1029890048 NOTICE: Additional mode: 1600x900 @ 60.00 - Full Screen
13:23:37 T:3152 M:1029890048 NOTICE: Additional mode: 1600x1200 @ 60.00 - Full Screen
13:23:37 T:3152 M:1029890048 NOTICE: Additional mode: 1680x1050 @ 60.00 - Full Screen
13:23:37 T:3152 M:1029890048 NOTICE: Additional mode: 800x600 @ 56.00 - Full Screen
13:23:37 T:3152 M:1029881856 NOTICE: Additional mode: 1440x900 @ 60.00 - Full Screen
13:23:37 T:3152 M:1029881856 NOTICE: Additional mode: 640x400 @ 70.00 - Full Screen
13:23:37 T:3152 M:1029881856 NOTICE: Additional mode: 1400x1050 @ 60.00 - Full Screen
13:23:37 T:3152 M:1029898240 NOTICE: load settings...
13:23:37 T:3152 M:1029795840 NOTICE: special://profile/ is mapped to: special://masterprofile/
13:23:37 T:3152 M:1029783552 NOTICE: loading special://masterprofile/guisettings.xml
13:23:37 T:3152 M:1029533696 NOTICE: Getting hardware information now...
13:23:37 T:3152 M:1029533696 NOTICE: Checking resolution 12
13:23:37 T:3152 M:1029521408 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
13:23:37 T:3152 M:1029513216 NOTICE: Loaded playercorefactory configuration
13:23:37 T:3152 M:1029505024 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
13:23:37 T:3152 M:1029500928 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
13:23:37 T:3152 M:1029496832 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
13:23:37 T:3152 M:1029496832 NOTICE: Default DVD Player: dvdplayer
13:23:37 T:3152 M:1029496832 NOTICE: Default Video Player: dvdplayer
13:23:37 T:3152 M:1029496832 NOTICE: Default Audio Player: paplayer
13:23:37 T:3152 M:1029541888 NOTICE: Loading media sources from special://masterprofile/sources.xml
13:23:37 T:3152 M:1006628864 NOTICE: initializing playlistplayer
13:23:37 T:3152 M:1006616576 NOTICE: DONE initializing playlistplayer
13:23:37 T:3152 M:1001644032 NOTICE: initialize done
13:23:37 T:3152 M:1001623552 NOTICE: Running the application...
13:23:37 T:3152 M:1001611264 NOTICE: ES: Starting event server
13:23:37 T:3024 M:1000812544 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
13:23:37 T:3024 M:1000800256 NOTICE: UDP: Listening on port 9777
13:25:00 T:3152 M:977633280 NOTICE: Storing total System Uptime
13:25:00 T:3152 M:977719296 NOTICE: Saving settings
13:25:00 T:3152 M:977666048 NOTICE: stop all
13:25:00 T:3152 M:977666048 NOTICE: ES: Stopping event server
13:25:00 T:3024 M:975790080 NOTICE: ES: UDP Event server stopped
13:25:00 T:3152 M:975802368 NOTICE: stop sap announcement listener
13:25:00 T:3152 M:975806464 NOTICE: clean cached files!
13:25:00 T:3152 M:975802368 NOTICE: unload skin
13:25:00 T:3152 M:986587136 NOTICE: stop python
13:25:00 T:3152 M:987795456 NOTICE: stopped
13:25:00 T:3152 M:987770880 NOTICE: destroy
13:25:00 T:3152 M:987746304 NOTICE: unload sections
Here is the file info for Avatar. It really doesnt matter if its avi, mkv or whatever, as soon as its 1080p i get stuttering and eventual audio sync issues (unless using MPC-HC). I saw the wiki page on making MPC-HC kick in and take over if files are 1080p or whatever, might just do that if you can't help.
General
Complete name : F:\BANNER\My Cinema\movies\avatar 1080p.mkv
Format : Matroska
File size : 10.9 GiB
Duration : 2h 41mn
Overall bit rate : 9 674 Kbps
Writing application : x264.exe
Writing library : mkv2rls v1.2 (date: 2010 febr 17)
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile :
[email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Container
[email protected]
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 41mn
Bit rate : 7 744 Kbps
Nominal bit rate : 8 171 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.156
Writing library : x264 core 93 r1542 5b86182
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=2pass / mbtree=1 / bitrate=8171 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 2h 41mn
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Title : English DTS 1509kbps
Language : English
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : English
Language : English
Text #2
Format : UTF-8
Title : English
Language : English
