2011-02-15, 15:03
2011-02-15, 15:29
if you're going to compile from source, yes. if you're going to use a prebuilt package, it'll be overwritten.
make sure that if you're going to test the pvr version, you do that as a different user than you normally use xbmc with OR make a backup of the ~/.xbmc/userdata/Database directory because the addon database is not compatible.
2011-02-15, 23:37
Thanks for the help. Haven't used Linux properly for years and have forgotten everything I used to do so will be fun compiling the PVR version myself.
Does somethig need to be change in the source when compiling so it doesn't overwrite XBMC?
2011-02-16, 00:37
Chrissssssss Wrote:Thanks for the help. Haven't used Linux properly for years and have forgotten everything I used to do so will be fun compiling the PVR version myself.
specify a new install prefix
./configure --prefix=/opt/dvr
or what ever you want.
2011-02-16, 00:41
Ok, thanks for that. I will have a try and probably get totally confused and mess everything up
2011-02-16, 05:55
An easier way is to just run each build in portable mode with -p
