2011-02-15, 17:09
2011-02-15, 19:17
use google, use ubuntu forum. Standard operation.
2011-02-22, 21:52
Hey well thnx, I did that now my xbmc is not loading anymore and just showing the login screen, I did this:
http://embraceubuntu.com/2006/01/29/move...partition/
I get the boot screen, thats loading XBMC, but XBMC does not start anymore, it just shows my login
What did i do wrong? =/ Shit man
When trying to start xbmc it says:
xbmc@XBMCLive:~$ xbmc
Error: unable to open display
FEH.py: cannot connect to X server
xbmc@XBMCLive:~$ Error: unable to open display
-bash: Error:: command not found
xbmc@XBMCLive:~$ FEH.py: cannot connect to X server
-bash: FEH.py:: command not found
xbmc@XBMCLive:~$ ^C
xbmc@XBMCLive:~$
xbmc@XBMCLive:~$ ^C
xbmc@XBMCLive:~$
2011-02-22, 21:58
if you followed those instructions, you should still have your old home under /oldhome
Do you?
Do you?
2011-02-22, 22:10
I deleted old home, cus i didnt test..... ehhehehe
2011-02-22, 22:19
Quote:I deleted old home, cus i didnt test..... ehheheheOk, then you have learnt something.
Follow the instructions exactly and make a backup. I am sure it can be fixed but it will be hard for anyone to figure out exactly what you did wrong.
BTW, next time find guide a bit newer than 2006....perhaps one written for the version of Ubuntu you are using.
2011-02-24, 00:18
Can I atleast get an URL to a good tutorial this time -.- help is not really been helpfull did a reinstlal.
