Would it be possible for this view to use banner.jpg instead of folder.jpg? I like to change views every now and then. Would save a lot of file renaming.
that would be against xbmc standards.
wiki Wrote:TV Shows
xbmc just uses folder.jpg no matter if it's a banner or a poster.
i know some skins hack around this and some don't...which only leads to confusion for the end-user.
Not a problem, don't know 'til you ask. Thanks for a great skin!
Isn't there a setting in the Advancedsettings.xml that will enable XBMC to recognize other naming options for thumbs...i.e banner.jpg?
<dvdthumbs>
A list of additional files to try when searching for dvdrom thumbnail images. (The default is folder.jpg which can be removed.)
<dvdthumbs>
<remove>folder.jpg</remove>
<add>thumb.jpg|cover.jpg</add>
</dvdthumbs>
<fanart>
A list of additional files to try when searching for fanart images. (The defaults are fanart.jpg and fanart.png which can be removed.)
<fanart>
<remove>fanart.jpg</remove>
<add>backdrop.jpg</add>
</fanart>
Mark
