Second post of the night, when I sometimes start up xbmc on the iPad it only fills up half the screen, if I quit I have to wait a few mins then go back in and it's ok, anyone experienced this?? Also once I have scanned items into the xbmc how do I bring up the menu that allows me to change info and update the library
Paul
Don't know about your screen issue I'm afraid - but try a double tap for the context sensitive menus
Hi Davilla
The only thing I can find is this. Darwin 10.4.0 I only downloaded it last night hope that helps
Paulkai Wrote:Hi Davilla
check /private/var/mobile/Library/Preferences/xbmc.log
