Full Version: [ATV2] Jitter on high bitrate x264 1080p file
Been playing all my 1080p movies without problem but stumbled on that one wich causes bad rendering. No buffering at all but a heavy jitter.
The bitrate (12.8 Mbps) is rather high compared to most of my files wich are all around 9 Mbps.
Are we hitting a limit to what the ATV2 can decode or is it something else?
xbmc.log : http://pastie.org/1576526
Mediainfo : http://pastie.org/pastes/1576426
Platform : AppleTV2 Wired Gigabit Network
Version : 4.2.1.
Build version :atv2 10.0-6 official
Install Method : dpkg
Jailbreak : Greenpoison rc6 / nitoTV
Thanks for all the good work all.
I don't think so. I had a short clip on youtube that demonstrated no jitter or drop frame playing back a scene from 1080p Iron Man2 with 23Mbps bitrate and some parts with sustain >17Mbps bitrate.
Unfortunately the video was flagged and subsequently blocked due to copyrights issue. :|
But it did good to demonstarted vtb-h264 was running well it bitrates higher than 23Mbps.
Can't report the same here. Several high bit rate avc/264 vids are stutter city for me on a wired network connection. Any of those same movies "handbraked" to a high profile 1080p play just fine.
