Full Version: Netflix and XBMC out of US in Apple TV 2g
Pages: 1 2 3
gonefishing1975 Wrote:I was able to setup netflix US using unblock-us but when I try to use Hulu the commercial plays then stips and goes back to the menu and quickly you see a message cannot find next video source or sometjing like that. Any idea as to why?
thanks
Are you using the Hulu Plugin by Bluecop in XBMC? If yes, under Hulu Plugin Add on settings, Ad, Pre-roll Ad, set to 0. Under Streaming, CDN = Akami.
Hey
I am using the bluecop plugin on m apple tv 2. I will try these settings thanks man.
dongdong
Works great now. thanks you rock!!!!!
gonefishing1975 Wrote:dongdong
All credit goes to Bluecop, for Hulu support, check out this discussion:
http://forum.xbmc.org/showthread.php?tid=121023
I can vouch for usvideo.org, I have been using it for over a year to stream Netflix mainly and works with all other US services. You simply enter the provided DNS servers into your router and all connected devices will then be able to stream US content.
Thanks members and Bluecop you rock!!!
Pages: 1 2 3
