Full Version: shutdown button doesn't work
Hi guys. I've got a problem that i'd like to solve: i'm using confluence skin and the shutdown button doesn't work, although in system settings the button is programmed to shut down the whole system; in fact, while pressing it, only xbmc closes. any suggests??
thank you!!
ps: i'm using xbmc on snow leopard
problem fixed, it was just a translation problem on system menu
Hello,
Quote:How do you fixed that ? I've the same issue... not very important but I'll appreciate that my mini shuts down where I choose the right button in xbmc Smile
Pb solved !
PS for the dev : great work ! I used to install Plex but I'm coming back to XBMC !
