2011-02-19, 19:46
Library mode scraping is not working when file sharing over FTP.
Example of my directory:
Wanted (2008)
Wanted-trailer.mp4
Wanted.mkv
Wanted.nfo
Wanted.tbn
When I add a source as FTP:
if .nfo file exists no posters or fanart, XBMC scraping or otherwise.
if .nfo file is removed, XBMC will scrape normally and not use any local
content.
When I add the same source as SMB:
everything works like a charm, scraper will use local content first, and
scrape if stuff is missing.
The obvious solution to this problem would be to just use SMB but in my case the library is running on WHS and I experience all sorts of lag issues when I use SMB, using FTP (buffers) solves all that and everything looks really smooth and responsive.
The FTP access is allowing XBMC full r/w control so that should not be an issue.
I have replicated the issue on different hardware.
Wanted (2008)
Wanted-trailer.mp4
Wanted.mkv
Wanted.nfo
Wanted.tbn
content.
