Full Version: TVSHOW(VIDEO INFO) this is good ?
Hello,
I have a question. (VIDEO INFO)
Indication methods of TVSHOW (a title level) are different, but will be good in this? :confused2:
My set is
Dharma10.0 and T! svn Rev.894
transparency Setting:
SKIN SETTING > GENERAL > TV shows - use posters : OFF
VIDEOS > LIBRARY > Flatten TV shows > NEVER
Ex. tvshow titles is "Persons Unknown" (GENRE is "science-fiction")
tvshow.nfo is made in Ember Media Manager.
Case A: Home menu > TV Shows (select) > Persons Unknown (A1) > season 1 (A2) > episodes (A3)
Case B: Home menu > TV Shows(submenu-GENRES) (select) > science-fiction (select) > Persons Unknown (B1) > season 1 (B2) > episodes (B3)
*: A1,A2,A3,B1,B2,B3 is video information.
The indication of B1 is different from A1.(title level):confused2:
Also submenu-year,actors,studio is the same.
The indication of B2 is same as A2.(season level)
The indication of B3 is same as A3.(episode level)
sorry bad english.
A1
B1
A2 , B2
thanx, i never noticed it myself, but yes i can confirm this issue.
i'm trying to create different info layouts for tvshows and seasons,
but this is not supported by xbmc.
in an effort to get it done anyway i'm using some workarounds which, until now, i thought worked fine.
i'll look into it and hopefully it's something easy to fix.
I have no real comment on this issue, but I want to say thank you OP. I'd never heard of that TV show before, but it sounds awesome. I'm planning on checking it out now.
Thank you for the reply.
I am looking forward to new VIDEO INFO. Laugh
can't fix it i'm afraid....not until this is implemented in xbmc:
http://trac.xbmc.org/ticket/7198
ronie Wrote:can't fix it i'm afraid....not until this is implemented in xbmc:
I understood.
It is a little disappointing.
By the way, extrafanart is not displayed in rev906. (only fanart is displayed).
Are you rightHuh?
(Rev904-hide fanart when extrafanart is available)
Old one was personally good. (Fanart and extrafanart are displayed. )
sorry.Blush
999unreal Wrote:I understood.
Are you rightHuh?
sorry.Blush
install a recent xbmc nightly build. ;-)
ronie Wrote:disclaimer:
  • if you want to use svn versions of T! you better make sure you'll also run a very recent nightly build of xbmc.
ronie Wrote:install a recent xbmc nightly build. ;-)
Thank you ronie.Wink
It was confirmed that it was normal in latest xbmc nightly build.
