i would like to remove/disable the back row skin. But when I go to the Skin settings the disable button will not highlight nor will uninstall only "change log"
I have XBMC installed on Ubuntu. Any help would be greatly appreciated.
guess you need you switch to another skin first.
Our plan to take over the skin world is almost complete!!!! Mwah-ha-hah!!!! Just kidding, you should ALWAYS have at least 2 skins if your using ours. Ours, and the default. (1 if not using ours.) So you would go into the settings, appearance, skin, click on the one shown (SHOULD already show Back Row since you said your using our skin.), then choose the other one that will show in the list. You can also check out different ones in the Add-on's under skin. Hopefully you'll find yourself coming back
Yes confluence is installed also and it says enabled.... confluence also does not allow me to uninstall or disable... just "change log"
so it says it hasx two skins enabled. How do I switch it back to confluence?
mee too stupid back row, im going to have to wipe the whole thing and set up all my movies again. AAAAAAAAAAAAARRRRRRRRRRRRRGGGGGGGGGGGGGGGGGG thanks stupid back row!!!!!
(2012-06-08, 13:06)OzDrDj Wrote: [ -> ]mee too stupid back row, im going to have to wipe the whole thing and set up all my movies again. AAAAAAAAAAAAARRRRRRRRRRRRRGGGGGGGGGGGGGGGGGG thanks stupid back row!!!!!
on the other hand, you could've asked how to switch back to confluence and people would have explained it to you.
but hey, if you prefer to re-install all your movies over and over again, who are we to deny you the pleasure.
