2011-02-20, 17:59
Is there a conditional that knows the difference between an "auto-generated" thumb, and an thumb that came from a filename.tbn, folder.jpg, or folder.tbn (user generated or scraped, just not pulled from a screengrab)?
As in:
<visible>!IsEmpty(ListItem.Thumb)</visible>
So that normal thumbs (filename.tbn) that are DVD case shape in aspect ratio, can be differentiated from "auto-generated" thumbs that are obviously 4:3 or 16:9 when created by XBMC from basically a screenshot of the media file.
I would like to be able to stretch proper thumbs to the DVD case aspect ratio, but I can't figure out a way to keep the "auto-generated" thumbs from getting squished into the same aspect ratio.
I checked the wiki, and tried every image type there, nothing.
I searched the forums, but it is not an easily search-able question.
Any ideas?
As in:
Any ideas?
