Quick (and probably easy) question: Where is the best place to keep looking to see when new official builds of XBMC get released? I put XBMC on my AppleTV last week, but would like an easy way to ensure I keep it updated.
Any advice would be appreciated.
You can check here..
http://mirrors.xbmc.org/apt/atv2/deb/
Or just randomly do apt-get update && apt-get upgrade, with the bug fixes happening at the moment I suspect updated releases will be sporadic.
Candor Wrote:You can check here..
Thanks... so looking at that the last update would have been on the 19th then? To simply do an update I guess I SSH as normal and type the commands you have stated?
