How do you guys organize your mini series?
The file don't show up in my tv shows for some reason in library mode
No.
S00E01.xxx
S00E02.xxx
S00E09.xxx
Hitcher Wrote:No.
S00E01.xxx
S00E02.xxx
S00E09.xxx
Ok thanks... i'll give that a shot
Or just E01, E02, ... E09 and add a regexp to specifically pick that up with a single capture.
I have tried a lot of things. I have named the 10 files; Part One...., S00E01...., S01E01...., 1-1.... But it still doesn't work. I have the folder with the 10 files in one folder named "The Pacific", which is in the folder I keep all my series (Glee, The Good Wife, etc.) and the others are picked up right. All except my mini series, like; Planet Earth, Roots, The Pacific, and Twin Peaks.
If I move the folder to the one where I keep films, they are picked up individually, but at least I have see them.
Any suggestions?
Bo
Do you have it as
The Pacific
-Season 1
--The Pacific S01E01.mkv/avi/etc
/The Pacific/s01e01, s01e02, etc
Works for me.
Hi Hitcher,
And you are using THETVDB for scraping these?
Bo
Yes, I just created that folder, made some dummy AVI files (s01e01.avi, etc) and ran a library update.
eroz Wrote:Do you have it as
The Pacific
-Season 1
+1
This is how I have it set up on my system (using TVDB)
OK, got "The Pacific" to work - thanks!!!
Now I only have problems with;
- Borgen, 2 season, each 2 folders (AUDIO_TS and VIDEO_TS)
- Roswell, 2 seasons, each 6 ISO files
- The West Wing, 7 season, each 6 ISO files
Any problems with ISO files, and/or AUDIO_TS/VIDEO_TS folders?
Bo
