2011-02-21, 09:29
2011-02-21, 10:15
You need to enable debug logging (System settings, System, Debugging) then start an add-on, then post the resulting xbmc.log on pastebin.com and post the link to it here. xbmc.log is in %appdata%\xbmc on Windows and in $Home/.xbmc/temp on Linux.
JR
JR
2011-02-21, 20:52
Found it.
2011-02-21, 21:04
2011-02-21, 21:08
there's "connection refused" everywhere in your log seems your xbmc don't access internet.
2011-02-21, 21:17
Why would the connection be refused if XBMC successfully downloaded all the info for the movies in my library?
How do I go about fixing this?
2011-02-21, 23:41
Does it have something to do with the settings?
2011-02-22, 10:01
It looks as if urllib2.urlopen is failing with 10061, which means the connection was refused. A connection refused error means that when your PC attempted to connect to a web server, that server refused to accept the connection. Is your web access through a proxy server or some other unusual method?
JR
JR
2011-02-24, 23:45
I dont know. What I do know is I have a time warner cable cable modem. I plug it in and I have internet access. Is there any way I can go about giving you a specific answer to your question?
2011-02-25, 12:35
For a quick test, open a Command prompt and type:
telnet http://www.ratsauce.co.uk 80
and see what happens. If you get an error post the error message here. If the command prompt screen blanks and shows just a flashing cursor it means the internet connection is (apparently) working. Click the X to close the command prompt.
JR
JR
2011-02-26, 03:22
It said:
'telnet' is not recognized as an internal or external command, operable program or batch file.
2011-02-26, 10:36
Ah, I forgot, Microsoft in their wisdom don't include telnet.exe in Windows 7 by default.
I don't use Windows 7, but on Server 2008 you install the telnet client from the "Features".
JR
JR
2011-02-26, 10:44
Quote:I don't use Windows 7, but on Server 2008 you install the telnet client from the "Features".Same on 7 & vista. Kind of a surprise first time...
2011-03-11, 05:21
Jhsrennie - I stubbled upon this post from google - I'm having the same problem as bomb squad with both the TVTunes & logo downloader scripts.
Do you have any other possible trouble shooting steps? I can access the sites these scripts are scraping from outside XMBC... but not from within side as XBMC returns with a connection refused error....
Thoughts?
Thoughts?
2011-03-11, 05:40
I'm an idiot - this thread actually got me thinking about that the issue might be with XBMC... well I was right - only it was a configuration thing I turned on by accident. Anyone with the same or similar problem - double check the network settings in XBMC and make sure it is NOT set to use a proxy.
If it is, you'll be able to get metadata - but NOT data from scripts. The connection will fail. The fact it's a bit inconsistent is worrisome - but still - its somewhat on the burden of the user to know what the hell they're doing... lol.
