Full Version: Caibration of GUI, but not Video?
Hi, i have a TV (HD-ready, 720p, HDMI from Graphics Card @ 720 60Hz) which obviously has a Overscan (graphics card Overscan is off)!
The thing is I want the skin being calibrated, but the calibration should not be used when playing videos. I can use the skinzoom levels, but -2, -4, -5 aren't enough, -6 is too much!
Is there a way just for calibrating the skin gui !?! (without using skinlevelzoom which is hardcoded at -2,-4, etc.)
PS: i used the screen calibration and the skin gui was fine after the calibration BUT: i had to set the zoom level of the movie (when watching video) to ORIGINAL, and EVEN there i get from a video source (1280, 720) sometimes things like 1279, 720!
To put in other words: don't want a system wide setting (which screen calibration is), just a skin calibration you could call!
Nope. Zoom is all you have.
jmarshall Wrote:Nope. Zoom is all you have.
Thx for the reply. Appretiate it.
Well ok, now I have -5 as zoomlöevel. It's OK, i can live with that.
But all the things like the dialogbar, timespan, everything which is display at the display bottom can not be seen to 100%.
For example i have found that in DialogSeekBar.xml (from confluence) there are some parameters
<coordinates>
<system>1</system>
<posx>820</posx>
<posy>650</posy>
</coordinates>
When i change the y-position to 640, i can see at least the seeking bar correctly.
My question is: Is there a general parameter somewhere which I can change so every bar from above is 10 pixels moved in y-direction?
(so i don't have to search every xml for such parameters and make a lot of trial-and-error runs)!
Nope - it completely depends on the skin. Some of them will be coded using relative coordinates to the bottom (eg 10r == 10 pixels from the bottom) others will be coded absolutely (I suspect most).
