Full Version: Weather+ Plugin Confluence
Hello
i have XBMC fully re-installed.
I would like the new weather Plugin.
I just weather-Plugin installed.
There is always a message below right:
Script error: Weather.weatherplus
How can I fix?
Best Regards
Xmedia
By default Confluence doesn't support Weather Plus. Check the first post of the Weather+ support thread for information on how to mod Confluence to support Weather+ (and check out the list of skins that already supports it).
Keep in mind that it does work under Confluence if you do a proper install. It's awesome and should be part of the standard release.
take a look to Influence dharma mod confluence and you have weathear plus plugin in
