On Mac Mini after upgrading to 10.0, when I select "Music" from the main menu it comes up with a blank window where I should be able to select my souces. "Video" and "Pictures" works fine. Ver 9 worked fine, have gone back to ver 9 for now.
Any ideas would be welcome.
johnsp,
Make sure that Show "Add source" buttons in file lists is turned on under SETTINGS->Appearance. I just turned it on and the Add source button showed up under Music. See if that helps.
"Add Sources" was selected, tried unselecting and reselecting - no change.
John
Go RIGHT off the main menu to go directly to one of the views and see what that gives you. Depending on what you have been playing with, you may be going to a view (eg the library) when you don't have content scanned in yet.
