2011-07-10, 07:45
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
2011-07-13, 14:44
Loaded up today and the script presents an error. Below is a link to the log. Thanks
http://pastebin.com/HXVgJhr5
2011-07-15, 18:46
fional Wrote:Loaded up today and the script presents an error. Below is a link to the log. Thanks
[UPDATED] v.2.2.1
- Fixed : Sunrise Time Bug of Weather.com 36 Hour Forecast
I hope it's working well on your system.
If any problems with fetching sunrise time, it'll show "N/A" instead of "Script Error".
* zip file : http://xbmc-addons.googlecode.com/files/..._2.2.1.zip
2011-07-15, 19:09
brightsr Wrote:[UPDATED] v.2.2.1
That's very cool! Thank you Brightsr!
2011-07-16, 22:48
would it be possible to add a show/hide option for heat index/wind chill?
2011-07-17, 16:49
i installed the weather plus but its not workin. i unstalled it n installed it again buit still not working. it keep giving me an error message.
2011-07-18, 19:45
steincol Wrote:i installed the weather plus but its not workin. i unstalled it n installed it again buit still not working. it keep giving me an error message.
Please let me know more informations like xbmc.log.
2011-07-18, 20:15
Hudson_Hawk04 Wrote:would it be possible to add a show/hide option for heat index/wind chill?
[UPDATED] v.2.2.2
- Added : Heat Index and Wind Chill from NOAA ( they will be shown as feels-like temperature, if not available, just "N/A". )
2011-07-19, 05:19
I'm also having issues. I just updated from the repo (Is it current?) But i still have the same issue. (I did just see a "Script Failed" option when i first tried using it.
It just sits on "Fetching forecast info" Here is the relevant part of the log. (I hope)
Cheers!
13:12:32 T:3084 M:3044003840 NOTICE: [PLUGIN] 'Weather Plus: Version - 2.2.2-r' initialized!
13:12:32 T:3084 M:3044007936 NOTICE: ** Found XBMC Revision: r0 [Unknown] **
13:12:32 T:3084 M:3039834112 NOTICE: [Weather.com+] Alternative Provider Selected : Accuweather.com Global (OCN|AU|ACT|CANBERRA)
13:12:33 T:3084 M:3039854592 NOTICE: Second error 503 for http://www.accuweather.com/OCN|AU|ACT|CANBERRA/hourly.aspx, increase sleep time.
13:12:34 T:3084 M:3040952320 NOTICE: Second error 503 for http://www.accuweather.com/OCN|AU|ACT|CANBERRA/hourly.aspx, increase sleep time.
13:12:34 T:3084 M:3040944128 ERROR: Error Type: <type 'exceptions.IndexError'>
13:12:34 T:3084 M:3040944128 ERROR: Error Contents: list index out of range
13:12:34 T:3084 M:3040718848 ERROR: Traceback (most recent call last):
File "C:\Users\Me\AppData\Roaming\XBMC\addons\weather.weatherplus\default.py", line 41, in <module>
Main()
File "C:\Users\Me\AppData\Roaming\XBMC\addons\weather.weatherplus\xbmcplugin_weather.py", line 76, in __init__
self._accu_hourly_forecast()
File "C:\Users\Me\AppData\Roaming\XBMC\addons\weather.weatherplus\xbmcplugin_weather.py", line 540, in _accu_hourly_forecast
forecasts = self.WeatherClient.accu_fetch_hourly_forecast()
File "C:\Users\Me\AppData\Roaming\XBMC\addons\weather.weatherplus\WeatherClient.py", line 2189, in accu_fetch_hourly_forecast
htmlSource = self._fetch_data( self.BASE_ACCU_FORECAST_URL % ( self.code, "hourly"+date[1] ), 1 )
IndexError: list index out of range
Cheers!
2011-07-19, 17:24
Freakish Wrote:I'm also having issues. I just updated from the repo (Is it current?) But i still have the same issue. (I did just see a "Script Failed" option when i first tried using it.
Code:13:12:32 T:3084 M:3044003840 NOTICE: [PLUGIN] 'Weather Plus: Version - 2.2.2-r' initialized!
Main()
Cheers!
According to your log, you need to re-select a location for Accuweather.com.
It's because form of area code has been changed since v.2.1.4 (multi-language supported).
In your case, the area code should be "en-us/au/australian-capital-territory/canberra", not "OCN|AU|ACT|CANBERRA".
I think I should've informed clearly about that.
2011-07-19, 23:56
Got the same problem with a script failed error.
Seems to just started doing this today at some point. Running last night's pre-eden nightly, v2.2.2 of the script. I reentered the 3 locations in the weather setup after deleting the script folder and the zip file in the packages directory. Downloaded new copy of the script and unzipped into the XBMC addon folder.
Here's a link to the log
http://pastebin.com/UG9VkuRR
Thank you for your time
2011-07-20, 01:34
Rygrath Wrote:Got the same problem with a script failed error.
I'll fix it soon. Thanks for your log.
2011-07-20, 02:17
Thank you for looking into it, much appreciated.
2011-07-20, 04:47
[UPDATED] v.2.2.3
- Fixed : US Local Forecast Video from Weather.com
2011-07-20, 05:03
brightsr Wrote:According to your log, you need to re-select a
Doh, Thanks! Yes it was working previously. I tried yesterday to check the settings, but the settings page wouldn't open. (Likely some PVR build bug) But tried it again this morning and reset the 3 accuweather points. And it's all working again as normal... Much Appreciate your time and efforts!
