2011-07-20, 05:16
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
2011-07-21, 02:29
Seems the magics have worn off Been getting script failed errors again after I closed XBMC and restarted it. No matter what I've tried it still errors out. Last attempt I installed a fresh clean instance of the latest nightly (7/20/11). Nothing else installed using Confluence and this is what comes up in the log on trying to fetch the information.
Full log here: http://pastebin.com/dcnEiLCu
Thanks again
17:23:24 T:6768 M:2068856832 ERROR: Error Type: <type 'exceptions.IndexError'>
17:23:24 T:6768 M:2068856832 ERROR: Error Contents: list index out of range
17:23:24 T:6768 M:2068586496 ERROR: Traceback (most recent call last):
File "E:\Nightlies\XBMC\portable_data\addons\weather.weatherplus\default.py", line 41, in <module>
Main()
File "E:\Nightlies\XBMC\portable_data\addons\weather.weatherplus\xbmcplugin_weather.py", line 99, in __init__
self._fetch_36_forecast()
File "E:\Nightlies\XBMC\portable_data\addons\weather.weatherplus\xbmcplugin_weather.py", line 370, in _fetch_36_forecast
alerts, alertsrss, alertsnotify, alertscolor, alertscount, forecasts, extras, video, video_local = self.WeatherClient.fetch_36_forecast( self.WEATHER_WINDOW.getProperty( "Video" ) )
File "E:\Nightlies\XBMC\portable_data\addons\weather.weatherplus\WeatherClient.py", line 1960, in fetch_36_forecast
video, video_local = self._create_video( parser.video_location, parser.video_local_location, parser.video_local_number, video )
File "E:\Nightlies\XBMC\portable_data\addons\weather.weatherplus\WeatherClient.py", line 2106, in _create_video
local_url = self.BASE_VIDEO_URL % ( local_location[0].replace(" ", "").lower(), )
IndexError: list index out of range
Thanks again
2011-07-21, 04:08
brightsr Wrote:[UPDATED] v.2.2.1Running 2.2.3 and my system is still showing the sunrise time an hour earlier than the other views.
- Fixed : Sunrise Time Bug of Weather.com 36 Hour Forecast
2011-07-21, 16:59
Rygrath Wrote:Seems the magics have worn off Been getting script failed errors again after I closed XBMC and restarted it. No matter what I've tried it still errors out. Last attempt I installed a fresh clean instance of the latest nightly (7/20/11). Nothing else installed using Confluence and this is what comes up in the log on trying to fetch the information.
Code:17:23:24 T:6768 M:2068856832 ERROR: Error Type: <type 'exceptions.IndexError'>
Main()
Thanks again
When I tested your location (93535) in the early morning, weather.com didn't work properly, which made a script error.
As for now (EST 11:00 AM), It's working perfectly on your location.
2011-07-21, 17:30
barcoboy Wrote:Running 2.2.3 and my system is still showing the sunrise time an hour earlier than the other views.
[UPDATED] v.2.2.4
- Fixed : Sunrise and Sunset Time Bug of Weather.com
2011-07-21, 19:26
When switching to Dutch language, the 10 day forecast gives N/A. Switching back to English, everything is OK. Did I miss a file somewhere? Or is it the Confluence skin, when setting to Dutch I can't select 'Region' anymore in the settings?
2011-07-21, 19:42
moosev Wrote:When switching to Dutch language, the 10 day forecast gives N/A. Switching back to English, everything is OK. Did I miss a file somewhere? Or is it the Confluence skin, when setting to Dutch I can't select 'Region' anymore in the settings?
Do you mean Accuweather.com language or xbmc's language?
And please let me review your log file.
2011-07-21, 20:16
brightsr Wrote:Do you mean Accuweather.com language or xbmc's language?
It's Xbmc's language.
2011-07-21, 20:18
moosev Wrote:It's Xbmc's language.
Can you post your log?
2011-07-21, 20:22
brightsr Wrote:Can you post your log?
I think it is the babelfish translation what's causing the N/A 's.
(turnig off this feature shows the english text)
(still working on how to post the log files)
2011-07-21, 20:27
moosev Wrote:I think it is the babelfish translation what's causing the N/A 's.
Oh, yes. I tested other langauges, Babelfish is causing the problem. I'll try to fix it.
Anyway, your log file always help me to find a problem.
2011-07-21, 21:00
[UPDATED] v.2.2.5
- Fixed : Babelfish Translation Bug of 10 Day Forecast
2011-07-21, 21:33
brightsr Wrote:[UPDATED] v.2.2.5
Super! That was really fast! Thanks.
2011-07-21, 21:59
how does my location need to be set up if I want to use NOAA as my provider?
2011-07-21, 22:30
brightsr Wrote:When I tested your location (93535) in the early morning, weather.com didn't work properly, which made a script error.
Man, Weather.com is biased against us High Desert people
In seriousness though, I just spent the last 20minutes trying out different cities in the US. Almost every one of them caused a script failed error except New York and Arlington West Virginia. Denver, Dallas, Orlando, Los Angeles, Knoxville, etc caused script errors.
Then I tried outside the US and all of them worked just fine, from London, Hong Kong, Sydney, Calgary, etc. I'd post a log, but it's generally the same error messages that I posted before.
I'll keep messing with it, but thought I'd share what I've run into.
