2011-07-31, 15:51
ThunderHawk4784 Wrote:I believe if the local video isn't available it should default back to the regional video.
If local video is unavailable, it won't show video.
So please select regional video at addon's settings.
brightsr Wrote:If local video is unavailable, it won't show video.
ThunderHawk4784 Wrote:The problem is that it isn't showing local video even when there is one available. I live near Milwaukee, WI so there is almost always a local video available on Weather.com. The plug in isn't recognizing that there is a video available for some reason. I understand that there probably won't be local video at night or on weekends, but all week long during the day there is local video available for my area. Something you may want to look into.
Burke Wrote:Hi,
I've been using weather plus for months now no problem until, I don't now for shore lets say a week ago when I lost satellite feed. I am from croatia so I usually take Italy satellite but it seams now I cant even chose one, tried uninstalling ad changing settings around but nothing happened.
I am on Win7 64 with Dharma running.
here is my debug log
brightsr Wrote:Okay, I understood. I'll check it up and try to fix it.
EDIT : I used the most popular video tap on the local weather page of weather.com in order to fetch proper local forecast video of the nearest city. But it can't be used now because there's no local video link in the most popular video tap. I think the only possible solution is to make an option to select a major city for a local video.
francxk Wrote:I got some error on retrieve weather for my town, because of some special character on the region name : grenoble, rhône alpe.
how can i fix that ?
francxk Wrote:What I see:
in accu_fetch_hourly_forecast method htmlSource_3 does not contains the grenoble forecasts, i think that is due to special character "ô",
http://www.accuweather.com/en-us/fr/rhôn...ourly.aspx works perfectly but it not the case in the python code.
Quote:10:16:21 T:352 NOTICE: [Weather Plus] Fetching URL : http://www.weather.com/weather/local/ASXX0075?
10:16:21 T:352 ERROR: Error Type: <type 'exceptions.TypeError'>
10:16:21 T:352 ERROR: Error Contents: cannot concatenate 'str' and 'list' objects
10:16:21 T:352 ERROR: Traceback (most recent call last):
File "D:\XBMC Dev\XBMC_New\portable_data\addons\weather.weatherplus\default.py", line 41, in <module>
Main()
File "D:\XBMC Dev\XBMC_New\portable_data\addons\weather.weatherplus\xbmcplugin_weather.py", line 112, in __init__
self._fetch_36_forecast()
File "D:\XBMC Dev\XBMC_New\portable_data\addons\weather.weatherplus\xbmcplugin_weather.py", line 387, in _fetch_36_forecast
alerts, alertsrss, alertsnotify, alertscolor, alertscount, forecasts, extras, video, video_local = self.WeatherClient.fetch_36_forecast( self.WEATHER_WINDOW.getProperty( "Video" ) )
File "D:\XBMC Dev\XBMC_New\portable_data\addons\weather.weatherplus\WeatherClient.py", line 1984, in fetch_36_forecast
video, video_local = self._create_video( parser.video_location, parser.video_local_location, parser.video_local_number, video )
File "D:\XBMC Dev\XBMC_New\portable_data\addons\weather.weatherplus\WeatherClient.py", line 2089, in _create_video
print "[Weather Plus] Video Location : " + location
TypeError: cannot concatenate 'str' and 'list' objects
