[UPDATE] v.2.4.0
Added : [Weather.com] Current Weather
- Forecast Videos Added(*):
U.S : All forecast videos from Weather.com,
*ABC, *CBS, *FOX, *NBC
Korea :
*KBS, *OBS, *Kweather
Japan :
*NHK
China :
*CCTV
U.K : Short and Long range forecast (SKY News),
*BBC
France :
*TF1, *France 2, Europe forecast (SKY News)
- Changed : Addon's settings
1) provider tab -> location #(1,2,3,...)
2) location name can be changed :
if you use weather.com, you should type a location name, or it may be shown blank.
3) location-provider coordinated
- Improved : Maps(from Weather.com) and Videos are available with all the providers.
- Fixed : [Accuweather.com] Unicode Error (e.g., île-de-france, rhône alpe.)
- Fixed : Misc. bugs
* .zip file download :
http://xbmc-addons.googlecode.com/files/..._2.4.0.zip
ok just tested this and am getting a couple issues. first off your addon xml needs updating i had to use one from the worldweatheronline addon that is in the xbmc.org repository to get it to enable. once that was out of the way i went ahead to set everything up. first i didnt understand the weather.com setup as you simply enter your location. i dont know what to put here i just put my town name Snohomish but that doesnt seem right. so i switched to accuweather which is what i normally used and picked snohomish wa unitied states. well it works berifly. i exit i out to home and get an error that the script failed went to weather section hit refresh and it works! but then as soon as i back out of the menu and it refresh the weather condidtion fanart it changes (the current weather) my temp goes to 770 degrees!!!! lol hot out. accuweather use to always wor for me and is the most accurate for my region and i use it on my phone too so i get same forcast. is the accuweather one not suppose to be working atm because i was getting failed derrors before the change to weather addons ill post a log in about 5 mins
Hack_kid Wrote:first i didnt understand the weather.com setup as you simply enter your location. i dont know what to put here i just put my town name Snohomish but that doesnt seem right.
Location name in the location tab is just a name, doesn't have any location information like area code. For weather.com, you can select location at XBMC's weather settings as you did on previous version. In other words, there's no change of a way to select a location.
Hack_kid : I've tested your location with Confluence skin on the latest nightly build, but there's no issue.
well everything works again thanks bro youre a real lifesaver...except for 4 days -.-'
hope you can fix it im using aeonmq3 atm
brightsr Wrote:Location name in the location tab is just a name, doesn't have any location information like area code. For weather.com, you can select location at XBMC's weather settings as you did on previous version. In other words, there's no change of a way to select a location.
Hello brightsr, test please with the today version eden, compiled by Montellese, look this post please:
http://forum.xbmc.org/showpost.php?p=936131&postcount=8
The addon weateher plus don´t appears more in Weather addon list, only new one addon by Spiff (World Weather Online Addon), and work fine here, but i love weather plus, I belive your addon xml needs updating.
Thanks,
Wanilton
Wanilton Wrote:Hello brightsr, test please with the today version eden, compiled by Montellese, look this post please:
Thanks,
Wanilton
Oh, I'll test soon! I was just waiting for a new build from git. Thanks!!
hentai23 Wrote:well everything works again thanks bro youre a real lifesaver...except for 4 days -.-'
My main skin is aeonmq3, too, and I don't see any issue now.
Please post your log and screenshot(if possible).
Dharma updated, working nicely so far. Thanks for your efforts.
It just autoupdated to 2.4.0 - thanks for bringing current weather back!
One remark: my setup from the signature is with confluence vertical and the temperature indicator on the top of the screen does not show anymore.
yay ...cant wait woot!!!
p.s: no temperature indicator nor the little weather icon at the top with me aswell as can be seen with the screenshots you only see the time and date
