This AM noticed that I got a Weatherplus script error. Looked at logs and said date format wrong (or something to that effect). Changed to Accuweather and results were OK. Changed back to NOAA and same script error. Changed back to Accuweather and OK. My testing seems to confirm it is the NOAA feed issue.
Have read with interest about wundeground and api. Hope you can get Weatherplus to use the agreed-upon api for Dharma users.
Thanks for your work, regards.
Notes: Dharma live (HD install), Florida location
brightsr Wrote:Thanks, Martijn!
It may be a good idea to safeguard this .zip file before it vanishes
Ok it seems to be an issue with the Skin. WHen I switch to Aeon NOX. it almost works.
I have 3 locations configured, Plover, WI, Levis, Quebec, Canada ad Hana, HI.
The forecast seems to be correcdt but the current condition don't seem to line up with the location. For instance Hana, HI current temperature is 32F. when the forecast is for 78F.
Here is a log
http://pastebin.com/j6vbVqwi
ijourneaux Wrote:Ok it seems to be an issue with the Skin. WHen I switch to Aeon NOX. it almost works.
Here is a log
I found a problem of weather alert and fixed it. Thanks and please wait for next update.
Here's the new string.xml in English which will be used in next update.
https://xbmc-addons.googlecode.com/svn/b...trings.xml
I really hope somebody can translate it into different languages as many as possible. Thank you very much in advance.
Note : For localization, I added some information in the first post of this thread.
I've been puzzling over this for several days. When I try to change the video in video slot #1, the change is saved in video slot #2. Changing slot 2 is saved in slot 3. If you try to change slot 3, you get a py error. I've tested this in Aeon nox and Transparency! (latest versions of both running under XBMCLive 10.1). The only way I can change slot 1, is to manually edit the xml file.
Also, I have been unable to get the background to be condition based. I've set to multi-image and pointed it to a copy of the weather backgrounds (in the numbered subfolders). Image never changes.
I searched the forum for several days and have been unable to find a fix. Any ideas?
something broke...
one of my providers suddenly lost the current degrees, current icon, 36hour forecasts and link to video forecasts(meteotv.bg)
xbmc.log
Send by XBMC Log Analyser
Rest of the data is fetched as expected.
I'm using 3.0.1 old-pre-eden, tried deleting it then deleting addon settings, nothing changed. Other two providers are OK.
macf1an Wrote:something broke...
xbmc.log
I don't see any weather plus log in your log, but I assume that you might have problem with Weather.com. If you do, that's an issue of weather alert which is going to be fixed in the next update.
macf1an Wrote:sorry about that - I was using a beta tool for analyzing and submitting logs which was too beta I guess..
http://pastebin.com/bfPfy8DQ
It's due to severe weather column in 36hours forecast of Weather.com.
I'll trying to fix it until next update.
EDIT : Fixed. Will be included in the next update.
meaning I should expect severe weather in the next 36 hours? thanks for the heads-up
Edit: currently it's OK - guess the alert is off
hello, i was wondering if it was possible so that this addon would update the weather forecast at start up, so that the conditional weather backgrounds in the skin I'm using will work, without first having to open the weather plugin.
