Please add Aeon Nox to the list of compatible skins on first post.
dascmo Wrote:Please add Aeon Nox to the list of compatible skins on first post.
I did. Thanks!
[Next Update Preview] Accuweather.com Global
- Default searching result for Gliwice, Poland (Weather.com)
- New searching result (Accuweather.com Global)
- Current Weather
- 36 hour forecast
Getting an error with Weather Plus recently using Dharma 10.1 and the latest stable T! skin.
Here is the error:
http://pastebin.com/fub8CRyR
TugboatBill Wrote:I'm running the latest update on 10.1 Live last night and noticed a minor bug. There was a weather alert and when I went to Weather from the Home menu there was a bunch of code displayed in the current conditions panel.
i'm seeing the same issue.
looks like the addon doesn't parse the alert info correctly:
weather location: Oakland (AR)
Debug Log:
http://pastebin.com/EQVrsjfk
Axodious Wrote:Getting an error with Weather Plus recently using Dharma 10.1 and the latest stable T! skin.
Here is the error: http://pastebin.com/fub8CRyR
I'm getting the exact same error today with 10.1, T! SVN, and weather location also in Canada.
i'm getting errors today too.
Latest everything.
Ditto on the Alert page errors.
V
barcoboy Wrote:I'm getting the exact same error today with 10.1, T! SVN, and weather location also in Canada.
Me too...
[UPDATE] v.1.2.1
- Fixed : Weather Alert
- Fixed : Canadian and European Video
- Added : Alternative Provider (Alpha ver., only for current, 36hour and 10day)
NOTE : Please use "$INFO[Window(Weather).Property(Location)]" instead of "$INFO[Weather.Location]"
brightsr Wrote:[UPDATE] v.1.2.1
will do & thanx for the fixes!
Working great again-thanks brightsr!
Oops-spoke a bit too soon... it looks like the Canada locations are not picking up the Canada national forecast video.
I am still able to link it directly at
http://v.imwx.com/v/wxflash/canada.flv, but I don't see any link to it anywhere anymore on my local forecast page in my web browser (location is Sherbrooke, QC, Canada).
The video format for Canada appears to have changed as well, while the regional US forecast video still looks the same (eg: Burlington, VT). I hope they are not phasing it out.
[UPDATE] v.2.0.0
- Alternative Provider : Accuweather.com Global Available
* HOW-TO-USE : addon's settings -> provider tab -> toggle on any location slot you want -> change location -> ENJOY!
* NOTE : XBMC always fetch current weather info. from weather.com regardless you toggle on alternative provider. So you may see weather info. you don't want briefly, which is totally normal.
- Fixed : Canadian and European Weather Video
brightsr Wrote:[UPDATE] v.2.0.0
I'm having trouble updating this time around. XBMC sees that there is an update for version 2.0.0, and seems to install it successfully, but then it notifies me that there is an update still available. The plugin works, but I still don't see the Canadian video link appear, nor a provider tab in the settings, and looking in xbmc.log, I see that it's still the old version that's running. I've tried reinstalling XBMC, recreating my profile, but no matter what I do, I can't get the update to happen. I did try upgrading to an svn version of XBMC last night to test something, but ended up uninstalling it and putting 10.1 back... but still no go. Any ideas?
