Full Version: How to run apps from network drives?
Is it possible to run apps from network drives in XBMC? For example, I have a few games and ps2 roms that can be set to work fully with the XBOX 360 controller and I would like to be able to load those apps, which are stored on another computer's harddrive, from within XBMC.
Yes, it should be possible. You dn't say how you plan to launch the apps. If you're using Launcher you need to either define a source that points to the network location in the File Manager, or in Windows map a drive letter to the network share.
JR
