Full Version: How to play DVD
Hi, Folks,
This should be brain-dead simple, no? How do you play a DVD?
I expected that it should either auto-launch when I insert the disc in the drive, or alternatively I should be able to start a DVD player application and hit Play.
I can ssh into the machine and see that the disc is mounted:
/dev/sr1 on /media/CRZ0NNW7 type udf (ro,nosuid,nodev,relatime,uid=1000,gid=1000,umask=77,iocharset=utf8)
From "Videos" at the main xbmc screen I can navigate into the files on the DVD, but it's not clear to me how to play them.
I am running today's stable version from live .iso image. The only possible rub is that I am trying it out in a VirtualBox virtual machine under OpenSuSE Linux 11.2 (or 11.3?)
Any pointers appreciated.
Cheers,
Steve
mccrew Wrote:From "Videos" at the main xbmc screen I can navigate into the files on the DVD, but it's not clear to me how to play them.
I think you normally play the .ifo file. Alternatively at the directory above, i.e. the point where selecting the DVD shows the files on it, select the DVD and press Play.
JR
