Full Version: No Channels in XBMC using TVHeadend with git build
Hey all,
I've compiled lars' xbmc-pvr branch today with some fixes for the device i'm using (related to rendering).
XBMC works great but when the tvheadend addon is enabled I don't get any guide info pulled or any channels listed..
All my other machines work fine from the same server (they are using lars' Dharma PVR build) - unfortunately I can't use that with this particular device as the GLES patches I have only appear to work with recent svn.
I've removed my whole '.xbmc' directory but it still doesn't pull anything from tvheadend.
Is there some new requirement for a certain tvheadend build or something ?? (I am using the one from lars' PPA)
Any advice would be appreciated!
"git pull" and try again. pushed some fixes after this post.
Thanks Lars, working fine on the latest pull Smile
Nice to see channel order and icons pulling from TVHeadend, also guide loading looks really fast!! Thanks for all the work you are doing on this.
Hi All,
Got the same issue, just installed tvheadend and added some channels.
I watch TV programs via web page.
But do not see any channels when I'm in LiveTV.
Is there log file I can look to identify the issue?
Updated XBMC with today's build and got my channels list.
