Full Version: [request] Option for larger font sizes
Hitcher,
I'd like to switch from Big Alaska to your Revisited but the Revisited text is smaller and harder to see - partly due to size and partly with very thin fonts.
Is there a way that you can make the font sizes larger and/or bolded (or an user settable option) in things like...
RSS - font is very thin, hard to see
Date - font is very thin, hard to see : like it to be larger too
Time - like it to be larger too
Info List & Files views - font is very thin, hard to see : like it to be larger too
btw... when is this skin going to be the default for XBMC Wink
Edit the font.xml.
Hitcher Wrote:Edit the font.xml.
I'll do this as I'm almost done porting a BIG Alaska theme (Blue Slate) - can you make an option in Settings to turn on/off larger text sizes? Thinking it would be nice to offer options for "regular" and "you might be going blind" Rofl ... since there are still a lot of people still using BIG.
Just make a new font set in the font.xml called Large or something.
