2011-02-28, 07:50
'Nystro' is a Skin inspired by the appearance of some cable tv epg software.Geared towards users who want basic functionality and ease of use.Built from the skin "Foundation"( Created by Hitcher / Textures courtesy of Jezz_X )additional textures for "Nystro" created by Bridgman
EXTRAS
PseudoTV incorporated
download this and place it in the AppData\Roaming\XBMC\addons\script.pseudotv\resources\skins folder:
http://www.mediafire.com/?5gtfc0r62tjh325
Weather fanart option
next aired incorporated
recently added incorporated
Cinema experience incorporated
tv tunes incorporated
TV logos incorporated
studio logos incorporated
record label logos incorporated
1 extrathumb used
horizontal home menu option
four custom links for home menu 2 favorites 2 scripts
popular genre links can be enabled as home menu links
here is an update with all the changes posted recently
Latest Update 3-6-11
pre-beta release DL
http://www.mediafire.com/?qakajt28a9e6eti
for some reason you must remove the skin.nystro folder from the addons folder and unzip and place the new one in its place
installing from zip file option has not been working properly for me
login
home
settings
settings category
weather
addon info
EXTRAS
1 extrathumb used
pre-beta release DL
login
home
settings
settings category
weather
addon info
