Hi, this might be stupid question, but I didn't find an answer. Is there a keyboard shortcut to start pictures slideshow? I mean, I open an image, press some key and slideshow starts? Thanks
By default there isn't a key to do it, but I note from that there is a function:
SlideShow(dir [,recursive, [not]random])
Starts a slideshow of pictures in the folder dir. Optional parameters are "recursive", and "random" or "notrandom" parameters. The "recursive" parameter starts a recursive slideshow, adding images from sub-folders. The "random" and "notrandom" parameters override the Randomize setting found in the pictures media window
You could easily create a userdata keymapping to start the slideshow, but I think this has to be a predetermined directory. I'm not sure how you'd make it start the slideshow in whatever is the current folder. Possibly this would be doable with a Python script.
JR
Did you find an answer? I'm too looking for it!
I didn't find a keyboard shortcut, using JSON for this now.
i'm not sure i follow, do you mean 'p'?
vasikgreif Wrote:I didn't find a keyboard shortcut, using JSON for this now.
How? Do you mind posting the code/script?
I was thinking of mapping a key in keymap.xml and call SlideShow(dir [,recursive, [not]random]) function. But, then I couldn't figure out how to get the "dir" of the selected folder!
I would like a solution for this as well!
