2011-03-01, 17:26
I'm not really sure if this is an XBMC issue or an unRAID issue so I plan on posting in both forums...
I am running the latest beta of unRAID (v5.0 b6) and the latest veersion of XBMC. I have found that NFS is a MUCH better protocol than SMB...especially while trying to stream Blu-Ray rips over gigabit. So naturally I have my "Movies" unRAID share mounted to /media/Movies in XBMC using NFS. Everything works great with one exception...
...if I add a new movie to the share and tell XBMC to "Update Library", the new movie is not added. XBMC acts as if no new movies have been found. Even if I turn off Library mode and look directrly at the source directory (/media/Movies), I still cannot see the new file. The only way I am able to see it is if I reboot my XBMC box. It is almost as if XBMC is only looking at a cached directory listing.
One note...I am currently using Wake-On-USB to power on (more wake up) my XBMC box. Could this be a factor? I kinda ruled it out since I am still able to see and play movies without the need for a reboot (i.e. XBMC does not lose connection to the Movies share).
Like I said, I plan on posting the same in the unRAID forums but I know there are quite a few people here that use the XBMC/unRAID combo. The x-factor however is NFS.
TIA,
John
TIA,
John
