Full Version: [REQ] TVTunes support
Pages: 1 2 3
First off, great job on this skin!
I'm hoping I am not alone in my request to see support for TVTunes added soon. Information can be found on the forums here (link provided below) but essentially for those that are not aware it will play the theme song for the show you are currently navigating.
http://forum.xbmc.org/showthread.php?tid=83925
night already support it.
Just in case, take a look in here please http://wiki.xbmc.org/index.php?title=Com...n_features
I have night 1.4.7 and I am missing this option as well.
The first page has 3 ways to get Night, the first is thru the repo which is an older version of Night as XBMC has a bug not allow us to update skins. Use one of the other 2 ways to get a build that supports TvTunes....
mcborzu Wrote:The first page has 3 ways to get Night, the first is thru the repo which is an older version of Night as XBMC has a bug not allow us to update skins. Use one of the other 2 ways to get a build that supports TvTunes....
@mcborzu when I select "Get more..." on the skin selection menu I see an option for "Night" and an option for "Night SVN" - would the latter be available as a result of my having the "Passion" repo already added? and If I am using the "Night SVN" would that skin also be affected by the bug you've noted? or would I get updated if the Passion repo upped a new version? I ask as I am using "Night SVN" but am not seeing the TVTunes support - or alternatively I'm doing something wrong.
DCowboy
update the skin night svn if you have already installed the repo.
I just downloaded this script and it downloaded my tv tunes fines but they won't play. I am using the Night Skin (SVN) via passion pit. Is there something I need to turn on?
yes turn it on in skin settings.
I went into System-Skin-Extra Options. I enabled 'Tv Themes'. They still don't play. Any ideas?
Is there another skin I can test this on?
You need to run the script first (in addons / programs).
This will allow you to grab those Tunes.
Cheers
Is TVTunes support broken in Night(SVN)?
I am using the latest Night(SVN) version 1303258124.
TVTunes plugin is installed.
And I've verified in another skin (Transparency) that TVTunes should be working.
replace script.TvTunes by script.tvtunes in include.xml.
Pages: 1 2 3
