Full Version: [LIVE] Sound is very quiet
Hi there
I recently got rid of my Media PC with XBMC and installed XBMC Live 10.4
Since then the audio output seems to be at line level, and is very difficult to hear, even if my speakers are turned up to max. I have tried different speakers and made sure that the level in XBMC is set to max.
Does anyone know how I can change the output level. My mainboard is a Foxconn 45CS-V2 and I am using the output jack on the mainboard to send the audio.
Cheers
Murray
Inside XBMC, go to Programs and select Audio Mixer. Ensure all levels are as desired.
If it's not there, go to System >> Add-ons >> Program Add-ons and install it.
h.udo
Thankyou so much, I had spent ages messing around with XML files inside the XBMC system...
